Aller au contenu principal
Magellan RoadMate 1200 Battery Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 1200 Battery Replacement, Back Cover: étape 1, image 1 de 2 Magellan RoadMate 1200 Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Battery Replacement: étape 2, image 1 de 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Battery Replacement: étape 3, image 1 de 2 Magellan RoadMate 1200 Battery Replacement: étape 3, image 2 de 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Battery Replacement: étape 4, image 1 de 2 Magellan RoadMate 1200 Battery Replacement: étape 4, image 2 de 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Battery Replacement, Battery: étape 5, image 1 de 3 Magellan RoadMate 1200 Battery Replacement, Battery: étape 5, image 2 de 3 Magellan RoadMate 1200 Battery Replacement, Battery: étape 5, image 3 de 3
    • Disconnect the battery connector from the circuit board.
    • Pry the battery off the circuit board. The adhesive attaching it shouldn't require any other tools.
4 autres ont terminé cette réparation.
Ross Light
Membre depuis le 04/12/10
217 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 10,457
