Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
A guide to accessing the GPS sensor.
Pièces
Aucune pièce spécifiée.
  1. Remove the four rubber caps from the back by using the Phillips #00 screwdriver. Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  5. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  6. Remove the two screws on that are located on opposite sides of the board.
    • Remove the two screws on that are located on opposite sides of the board.
  7. Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
  8. Carefully flip the circuit board out so you can get to the sensor easily. Remove the tape holding the sensor to the display and take out the sensor.
    • Carefully flip the circuit board out so you can get to the sensor easily.
    • Remove the tape holding the sensor to the display and take out the sensor.
Ross Light
Membre depuis le 12/04/2010
175 Réputation
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 3,033
