Introduction
A quick guide to accessing the RoadMate's motherboard.
Pièces
Aucune pièce nécessaire.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
  2. Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
    • Unscrew the 2 screws on either side of the board.
    • Lift the circuit board up and disconnect the GPS connector.
Ross Light
Membre depuis le 12/04/2010
175 Réputation
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 20
30 derniers jours : 26
Total : 4,835
