Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Magellan RoadMate 1200 Speaker Replacement
Ce dont vous avez besoin
    1. Magellan RoadMate 1200 Speaker Replacement, Back Cover: étape 1, image 1 de 2 Magellan RoadMate 1200 Speaker Replacement, Back Cover: étape 1, image 2 de 2
      • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Magellan RoadMate 1200 Speaker Replacement: étape 2, image 1 de 1
      • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
      Demander à FixBot
    3. Magellan RoadMate 1200 Speaker Replacement: étape 3, image 1 de 2 Magellan RoadMate 1200 Speaker Replacement: étape 3, image 2 de 2
      • Remove the back cover from the device by separating the back cover along its seam.
      • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
      Demander à FixBot
    4. Magellan RoadMate 1200 Speaker Replacement: étape 4, image 1 de 2 Magellan RoadMate 1200 Speaker Replacement: étape 4, image 2 de 2
      • Pull the speaker cord, horizontally, by its base, away from the motherboard.
      • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
      Demander à FixBot
    1. Magellan RoadMate 1200 Speaker Replacement, Speaker: étape 5, image 1 de 3 Magellan RoadMate 1200 Speaker Replacement, Speaker: étape 5, image 2 de 3 Magellan RoadMate 1200 Speaker Replacement, Speaker: étape 5, image 3 de 3
      • Once you pull off the back cover, remove the orange piece of tape on the speaker.
      • Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
      Demander à FixBot
    2. Magellan RoadMate 1200 Speaker Replacement: étape 6, image 1 de 1
      • Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
      Demander à FixBot
Ross Light
Membre depuis le 04/12/10
217 Réputation
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 37
Total : 2,715
