Aller au contenu principal
Magellan RoadMate 1440 Power Switch Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: étape 1, image 1 de 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: étape 2, image 1 de 2 Magellan RoadMate 1440 Power Switch Replacement: étape 2, image 2 de 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: étape 3, image 1 de 2 Magellan RoadMate 1440 Power Switch Replacement: étape 3, image 2 de 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: étape 4, image 1 de 3 Magellan RoadMate 1440 Power Switch Replacement: étape 4, image 2 de 3 Magellan RoadMate 1440 Power Switch Replacement: étape 4, image 3 de 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: étape 5, image 1 de 3 Magellan RoadMate 1440 Power Switch Replacement: étape 5, image 2 de 3 Magellan RoadMate 1440 Power Switch Replacement: étape 5, image 3 de 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: étape 6, image 1 de 1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
Jeremy Johnson
Membre depuis le 03/21/16
201 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 7-3, Benson Spring 2016 Membre de l'équipe Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 195
