Aller au contenu principal
Magellan RoadMate 2120T-LM Display Assembly Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: étape 1, image 1 de 3 Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: étape 1, image 2 de 3 Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: étape 1, image 3 de 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 2, image 1 de 2 Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 2, image 2 de 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 3, image 1 de 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 4, image 1 de 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Display Assembly Replacement, Motherboard: étape 5, image 1 de 1
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 6, image 1 de 2 Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 6, image 2 de 2
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 7, image 1 de 3 Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 7, image 2 de 3 Magellan RoadMate 2120T-LM Display Assembly Replacement: étape 7, image 3 de 3
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
  8. Magellan RoadMate 2120T-LM Display Assembly Replacement, Display Assembly: étape 8, image 1 de 2 Magellan RoadMate 2120T-LM Display Assembly Replacement, Display Assembly: étape 8, image 2 de 2
    • Pry back on the plastic shell surrounding the touchscreen and remove the screen.
John Doe
Membre depuis le 01/12/16
503 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 244
