Aller au contenu principal
Magellan RoadMate 2120T-LM Speaker Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 2120T-LM Speaker Replacement, Battery: étape 1, image 1 de 3 Magellan RoadMate 2120T-LM Speaker Replacement, Battery: étape 1, image 2 de 3 Magellan RoadMate 2120T-LM Speaker Replacement, Battery: étape 1, image 3 de 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Speaker Replacement: étape 2, image 1 de 2 Magellan RoadMate 2120T-LM Speaker Replacement: étape 2, image 2 de 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Speaker Replacement: étape 3, image 1 de 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Speaker Replacement: étape 4, image 1 de 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Speaker Replacement, Speaker: étape 5, image 1 de 2 Magellan RoadMate 2120T-LM Speaker Replacement, Speaker: étape 5, image 2 de 2
    • Locate the internal speaker just above the battery
    • Remove the two 3 mm Phillips #1 screws.
John Doe
Membre depuis le 01/12/16
503 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 100
