Aller au contenu principal
Magellan RoadMate 5120-LMTX Battery Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: étape 1, image 1 de 3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: étape 1, image 2 de 3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: étape 2, image 1 de 3 Magellan RoadMate 5120-LMTX Battery Replacement: étape 2, image 2 de 3 Magellan RoadMate 5120-LMTX Battery Replacement: étape 2, image 3 de 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: étape 3, image 1 de 2 Magellan RoadMate 5120-LMTX Battery Replacement, Battery: étape 3, image 2 de 2
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: étape 4, image 1 de 3 Magellan RoadMate 5120-LMTX Battery Replacement: étape 4, image 2 de 3 Magellan RoadMate 5120-LMTX Battery Replacement: étape 4, image 3 de 3
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
Steven Prout
Membre depuis le 10/08/16
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 4-4, Wilson Fall 2016 Membre de l'équipe IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 498
