Aller au contenu principal
Magellan RoadMate 5236T-LM Back Cover Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: étape 1, image 1 de 3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: étape 1, image 2 de 3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: étape 1, image 3 de 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Back Cover Replacement: étape 2, image 1 de 3 Magellan RoadMate 5236T-LM Back Cover Replacement: étape 2, image 2 de 3 Magellan RoadMate 5236T-LM Back Cover Replacement: étape 2, image 3 de 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Back Cover Replacement: étape 3, image 1 de 2 Magellan RoadMate 5236T-LM Back Cover Replacement: étape 3, image 2 de 2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
Megan Scribner
Membre depuis le 10/18/16
315 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-7, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 169
