Introduction
In this replacement guide you're going to learn how to replace a faulty battery. It's important to go to the trouble shooting page first in order to know that you need to replace the battery and it's not some other issue that you actually need to solve first.
Ce dont vous avez besoin
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
Use tweezers to disconnect the ZIF connector from the motherboard.
Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
2 commentaires
Please describe what voltage to expect on the batterie’s (cell) black, white, and red wires. Also if possible what their individual functions are?
