Aller au contenu principal
Magellan RoadMate 5236T-LM Speaker Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: étape 1, image 1 de 3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: étape 1, image 2 de 3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: étape 1, image 3 de 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Speaker Replacement: étape 2, image 1 de 3 Magellan RoadMate 5236T-LM Speaker Replacement: étape 2, image 2 de 3 Magellan RoadMate 5236T-LM Speaker Replacement: étape 2, image 3 de 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Speaker Replacement: étape 3, image 1 de 2 Magellan RoadMate 5236T-LM Speaker Replacement: étape 3, image 2 de 2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: étape 4, image 1 de 2 Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
    • Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
  5. Magellan RoadMate 5236T-LM Speaker Replacement: étape 5, image 1 de 1
    • Unscrew the two 5mm screws using a Phillips #000 screwdriver.
  6. Magellan RoadMate 5236T-LM Speaker Replacement: étape 6, image 1 de 3 Magellan RoadMate 5236T-LM Speaker Replacement: étape 6, image 2 de 3 Magellan RoadMate 5236T-LM Speaker Replacement: étape 6, image 3 de 3
    • Use a Phillips #000 screwdriver to remove three 5mm screws that hold the motherboard down to the the back panel.
    • Remove the battery, speaker and motherboard. Place them on a flat surface upside down.
  7. Magellan RoadMate 5236T-LM Speaker Replacement: étape 7, image 1 de 1
Felix Muwanguzi
Membre depuis le 10/24/16
379 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-7, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 membres
5 tutoriels rédigés
Un commentaire
Where can I find a replacement speaker?
Tom Phillips - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 149
