Aller au contenu principal
Magellan Roadmate 9055-LM Button Replacement
Ce dont vous avez besoin
  1. Magellan Roadmate 9055-LM Button Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: étape 1, image 1 de 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Button Replacement: étape 2, image 1 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 2, image 2 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 2, image 3 de 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Button Replacement: étape 3, image 1 de 2 Magellan Roadmate 9055-LM Button Replacement: étape 3, image 2 de 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Button Replacement: étape 4, image 1 de 2 Magellan Roadmate 9055-LM Button Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Button Replacement: étape 5, image 1 de 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Button Replacement: étape 6, image 1 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 6, image 2 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 6, image 3 de 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Button Replacement: étape 7, image 1 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 7, image 2 de 3 Magellan Roadmate 9055-LM Button Replacement: étape 7, image 3 de 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Button Replacement: étape 8, image 1 de 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Button Replacement, Button: étape 9, image 1 de 1
    • Locate button
  10. Magellan Roadmate 9055-LM Button Replacement: étape 10, image 1 de 1
    • The button can be easily removed and can now be replaced
Giovanni
Membre depuis le 10/18/16
313 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 89
