Aller au contenu principal
Magellan Roadmate 9055-LM Touchscreen Replacement
Ce dont vous avez besoin
  1. Magellan Roadmate 9055-LM Touchscreen Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: étape 1, image 1 de 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 2, image 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 2, image 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 2, image 3 de 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 3, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 3, image 2 de 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 4, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 5, image 1 de 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 6, image 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 6, image 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 6, image 3 de 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 7, image 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 7, image 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 7, image 3 de 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 8, image 1 de 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: étape 9, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: étape 9, image 2 de 2
    • Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
  10. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 10, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 10, image 2 de 2
    • Remove all the electrical tapes from different places as indicated.
  11. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 11, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 11, image 2 de 2
    • Remove the white clip attached with black and white wires.
    • Carefully remove the clip by pulling it to the opposite side from the clip.
  12. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 12, image 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 12, image 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 12, image 3 de 3
    • Unplug the wires by pushing it down and slowly pulling it towards you.
    • After unplugging the wires, take the motherboard out.
  13. Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: étape 13, image 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: étape 13, image 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: étape 13, image 3 de 3
    • Unscrew four Phillips #1 screws.
    • Remove the two metal pieces on two corners.
  14. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 14, image 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: étape 14, image 2 de 2
    • Lift touchscreen from the right side.
    • Slide the touch screen out from the top left corner.
  15. Magellan Roadmate 9055-LM Touchscreen Replacement: étape 15, image 1 de 1
    • Place the touchscreen gently on the table.
YuChe Chang
Membre depuis le 10/18/16
202 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 284
