Introduction
Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
Ce dont vous avez besoin
Use pliers to grip the gear inside of the top of the device.
Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
Wedge a flathead screwdriver in between the casing and white plastic activator.
Pry the white plastic activators from the casing as needed.
3 autres ont terminé cette réparation.
4 commentaires
You gotta be kidding me?
Where would you get replacement activators or spring beneath these? How much would that cost?
