Aller au contenu principal
Magic Bullet MB1001B Power Cord Replacement
Ce dont vous avez besoin
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: étape 2, image 1 de 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: étape 3, image 1 de 1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: étape 4, image 1 de 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: étape 5, image 1 de 1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: étape 6, image 1 de 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: étape 7, image 1 de 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
2 autres ont terminé cette réparation.
Bridget Carr
Membre depuis le 10/06/15
266 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 12-13, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 membres
8 tutoriels rédigés
2 commentaires
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Réponse
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 2,438
