Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Magic Bullet NutriBullet Outside Casing Replacement
Ce dont vous avez besoin
    1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: étape 1, image 1 de 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Demander à FixBot
      Ajouter un commentaire
    2. Magic Bullet NutriBullet Outside Casing Replacement: étape 2, image 1 de 2 Magic Bullet NutriBullet Outside Casing Replacement: étape 2, image 2 de 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Demander à FixBot
    3. Magic Bullet NutriBullet Outside Casing Replacement: étape 3, image 1 de 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Demander à FixBot
    4. Magic Bullet NutriBullet Outside Casing Replacement: étape 4, image 1 de 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Demander à FixBot
    5. Magic Bullet NutriBullet Outside Casing Replacement: étape 5, image 1 de 2 Magic Bullet NutriBullet Outside Casing Replacement: étape 5, image 2 de 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Demander à FixBot
    6. Magic Bullet NutriBullet Outside Casing Replacement: étape 6, image 1 de 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Demander à FixBot
    7. Magic Bullet NutriBullet Outside Casing Replacement: étape 7, image 1 de 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Demander à FixBot
    1. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: étape 8, image 1 de 1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      Demander à FixBot
5 autres ont terminé cette réparation.
Angela Wong
Membre depuis le 01/22/15
1 177 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 19-8, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 membres
72 tutoriels rédigés
4 commentaires de tutoriel
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - Réponse Partager
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - Réponse Partager
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - Réponse Partager
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 30
30 derniers jours : 94
Total : 8,896
