Aller au contenu principal
Magic Bullet NutriBullet Power Cord Replacement
Ce dont vous avez besoin
  1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: étape 1, image 1 de 2 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: étape 1, image 2 de 2
    • Before beginning, make sure the device is unplugged.
    • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
  2. Magic Bullet NutriBullet Power Cord Replacement: étape 2, image 1 de 1
    • Once the screws are removed, pull the plastic base up gently.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  3. Magic Bullet NutriBullet Power Cord Replacement: étape 3, image 1 de 1
    • Gently lift the power cord from its side slot and place it to the side.
  4. Magic Bullet NutriBullet Power Cord Replacement: étape 4, image 1 de 2 Magic Bullet NutriBullet Power Cord Replacement: étape 4, image 2 de 2
    • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
    • The white safety bracket holds the cord down. After removing it, the cord will be free.
  5. Magic Bullet NutriBullet Power Cord Replacement: étape 5, image 1 de 1
    • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
    • Gently pull out the two plastic covers at the end of the wires.
  6. Magic Bullet NutriBullet Power Cord Replacement: étape 6, image 1 de 1
    • Use tape or clamps to hold the wires together for an easy soldering experience.
    • Using a soldering iron, solder your new wire to the red wire.
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
3 autres ont terminé cette réparation.
Geary Yu
Membre depuis le 01/22/15
1 217 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 19-8, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 membres
10 tutoriels rédigés
6 commentaires
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
florentinokarenjoy24 - Réponse
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Michael Lee - Réponse
Can I plug the Magic Bullet in 220v?
Sovelita Tenerife - Réponse
Where can I get a replacement cable from?
victoria hatton - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 103
Total : 15,120
