Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Magic Bullet NutriBullet Rubber Gasket Replacement
Ce dont vous avez besoin
    1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: étape 1, image 1 de 1
      • Separate the blending blade lid from the cup.
      Demander à FixBot
      Ajouter un commentaire
    2. Magic Bullet NutriBullet Rubber Gasket Replacement: étape 2, image 1 de 2 Magic Bullet NutriBullet Rubber Gasket Replacement: étape 2, image 2 de 2
      Outil utilisé dans cette étape :
      • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
      • Slowly pry the rubber gasket up.
      Demander à FixBot
Geary Yu
Membre depuis le 01/22/15
1 277 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 19-8, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 membres
72 tutoriels rédigés
11 commentaires de tutoriel
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Réponse Partager
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Réponse Partager
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Réponse Partager
Thanks a lot.
Kayla Martin - Réponse Partager
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Réponse Partager
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 54
30 derniers jours : 164
Total : 38,601
