Introduction
The main board needs to be partially removed for several of the steps, so completely removing and replacing it isn't too much more work. This should be done as a last resort if nothing else works when fixing the iP37.
Ce dont vous avez besoin
Outil utilisé dans cette étape :iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Peel away the tape holding down the wires between the main board and the DC power and 3.5 mm audio jack board.
