Aller au contenu principal
Making a low cost photography light stand
Ce dont vous avez besoin
  1. Making a low cost photography light stand, Unplug the lamp: étape 1, image 1 de 1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: étape 2, image 1 de 3 Making a low cost photography light stand, Remove the lightbulb: étape 2, image 2 de 3 Making a low cost photography light stand, Remove the lightbulb: étape 2, image 3 de 3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: étape 3, image 1 de 3 Making a low cost photography light stand, Remove the socket cover: étape 3, image 2 de 3 Making a low cost photography light stand, Remove the socket cover: étape 3, image 3 de 3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: étape 4, image 1 de 2 Making a low cost photography light stand, Remove the bulb socket: étape 4, image 2 de 2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: étape 5, image 1 de 3 Making a low cost photography light stand, Remove the cord: étape 5, image 2 de 3 Making a low cost photography light stand, Remove the cord: étape 5, image 3 de 3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: étape 6, image 1 de 1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
Ligne d'arrivée
Nick
Membre depuis le 11/10/09
88 752 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 521 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 445
