Aller au contenu principal
Makita DT01 Battery Replacement
  1. Makita DT01 Battery Replacement, Battery: étape 1, image 1 de 3 Makita DT01 Battery Replacement, Battery: étape 1, image 2 de 3 Makita DT01 Battery Replacement, Battery: étape 1, image 3 de 3
    • Lay the device down on its side.
  2. Makita DT01 Battery Replacement: étape 2, image 1 de 1
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Battery Replacement: étape 3, image 1 de 1
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
Victoria Scira
Membre depuis le 02/15/17
226 Réputation
2 tutoriels rédigés
Un commentaire
Replacement for Makita DT01 Power Tool Battery
Type: Li-ion
Volt: 10.8V
Capacity: 3000mAh
Color: Black
Weight: 166g
Dimension: 50.75 x 50.20 x 77.80mm
You can contact this seller for a lower price if you want a quantity purchase of Makita DT01 replacement batteries on https://www.drill-battery.net.au/buybatt...
Drillbatterycomau - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 569
