Aller au contenu principal
Makita GA4030K Armature Replacement
Ce dont vous avez besoin
  1. Makita GA4030K Armature Replacement, Disk Cover: étape 1, image 1 de 1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: étape 2, image 1 de 1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: étape 3, image 1 de 2 Makita GA4030K Armature Replacement: étape 3, image 2 de 2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: étape 4, image 1 de 2 Makita GA4030K Armature Replacement: étape 4, image 2 de 2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: étape 5, image 1 de 2 Makita GA4030K Armature Replacement, Back Cover: étape 5, image 2 de 2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: étape 6, image 1 de 1
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: étape 7, image 1 de 2 Makita GA4030K Armature Replacement, Armature: étape 7, image 2 de 2
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: étape 8, image 1 de 2 Makita GA4030K Armature Replacement: étape 8, image 2 de 2
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: étape 9, image 1 de 3 Makita GA4030K Armature Replacement: étape 9, image 2 de 3 Makita GA4030K Armature Replacement: étape 9, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: étape 10, image 1 de 2 Makita GA4030K Armature Replacement: étape 10, image 2 de 2
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: étape 11, image 1 de 2 Makita GA4030K Armature Replacement: étape 11, image 2 de 2
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: étape 12, image 1 de 1
    • Remove the armature.
5 autres ont terminé cette réparation.
Laura Ann Jagels
Membre depuis le 04/01/15
490 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 16
Total : 3,400
