Aller au contenu principal
Makita GA4030K Grease Replacement
Ce dont vous avez besoin
  1. Makita GA4030K Grease Replacement, Disk Cover: étape 1, image 1 de 1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Grease Replacement: étape 2, image 1 de 1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Grease Replacement: étape 3, image 1 de 2 Makita GA4030K Grease Replacement: étape 3, image 2 de 2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Grease Replacement: étape 4, image 1 de 2 Makita GA4030K Grease Replacement: étape 4, image 2 de 2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Grease Replacement, Grease: étape 5, image 1 de 1
    • Unscrew the four 15 mm pan head screws using a Phillips #02 screwdriver.
  6. Makita GA4030K Grease Replacement: étape 6, image 1 de 1
    • Remove the face of the device. You may need to jiggle it a little to get it off.
    • Once you see the grease, it should appear to be speckled with either dirt particles, fragments of metal, or look dark and lumpy. If you grease does not look like this, then you do not need to replace it.
  7. Makita GA4030K Grease Replacement: étape 7, image 1 de 1
    • Use a metal spudger to scrape the old grease from the cavity.
  8. Makita GA4030K Grease Replacement: étape 8, image 1 de 1
    • Blow compressed air into the device to make sure it is completely clean.
    • Squeeze in enough grease to fill the indents inside of the cavity.
    • Use a metal spudger to spread the grease evenly across the face of the device.
2 autres ont terminé cette réparation.
Laura Ann Jagels
Membre depuis le 04/01/15
490 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 membres
13 tutoriels rédigés
5 commentaires
Hi, what is the recommended grease?
Robert Chua - Réponse
Hi. You’re great.
William Diffin - Réponse
Can I use white lithium grease. Thanks my brushes appear to about half an inch long if the grease doesn’t work going to try them????
Dan Faerber - Réponse
Angle grinders use a PAO lithium soap grease. Most use Nye Lubricants RheoLube 380, which is hard to source or expensive to buy.
You may substitute with Dupont Molykote G4700 grease. ereplacementParts.com has the Nye grease.
Emilio Gonzalez - Réponse
Hi, I’m trying to replace the spindle of my ga4030 with the one from the ga4530, to effectively make it into a 4-1/2” model. Looking at the parts list for both of these grinders, it appears they are identical except for the spindle, disc retaining nuts, and wheel shroud/guard. Do you know if this mod is possible? It looks like I would just need to remove that small bearing that’s pressed on to the top of the spindle.
Drew - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 72
Total : 8,472
