Aller au contenu principal
Makita XPH01 Forward/Reverse Switch Replacement
Ce dont vous avez besoin
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: étape 1, image 1 de 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: étape 2, image 1 de 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: étape 3, image 1 de 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: étape 4, image 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: étape 4, image 2 de 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: étape 5, image 1 de 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: étape 6, image 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: étape 6, image 2 de 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: étape 7, image 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: étape 7, image 2 de 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: étape 8, image 1 de 1
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: étape 9, image 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: étape 9, image 2 de 2
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
2 autres ont terminé cette réparation.
Eric Herwatt
Membre depuis le 10/05/16
984 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 15-4, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 55
Total : 5,812
