Aller au contenu principal
Maquet Servo-U Expiratory Cassette Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
  1. Maquet Servo-U Expiratory Cassette Replacement, Expiratory Cassette: étape 1, image 1 de 1
    • Orient the ventilator so the upgrade slots (front) are facing away from you and that you are looking at the back of the device.
    • Switch off the ventilator system using the on/off switch on the patient unit, which is located on on the lower half of the unit behind a white door panel.
    • Disconnect the ventilator system from the mains power and gas supply.
  2. Maquet Servo-U Expiratory Cassette Replacement: étape 2, image 1 de 1
    • In the following order:
    • Press the button on the expiratory cassette.
    • Tilt the cassette upwards and remove.
    • The expiratory cassette is a precision instrument and must be handled carefully.
  3. Maquet Servo-U Expiratory Cassette Replacement: étape 3, image 1 de 1
    • Hinge the expiratory cassette and press it firmly down into lock position.
    • Make sure that the cassette clicks into position. Check that it cannot be moved upwards and that the button on top of the cassette is completely ejected.
Ligne d'arrivée
Cassandra Aarrestad
Membre depuis le 01/23/20
627 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S7-G2, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 55
Total : 3,140
