Aller au contenu principal
Marco UP Series Electric Pump Assembly
Ce dont vous avez besoin
    • Place the brusholder on the table, face up.
    • Follow the steps in the video to move the brushes' springs out of the way.
    • Pull the brushes away from the center.
    • Come back here if in the next steps the stator magnets suck up the rotor.
  1. Marco UP Series Electric Pump Assembly, Insert the spring and the ball bearing: étape 2, image 1 de 3 Marco UP Series Electric Pump Assembly, Insert the spring and the ball bearing: étape 2, image 2 de 3 Marco UP Series Electric Pump Assembly, Insert the spring and the ball bearing: étape 2, image 3 de 3
    • First, fit the round spring in the hole.
    • Then, insert the ball bearing and press a little to be sure that it touches completely on the bottom.
  2. Marco UP Series Electric Pump Assembly, Insert the rotor: étape 3, image 1 de 2 Marco UP Series Electric Pump Assembly, Insert the rotor: étape 3, image 2 de 2
    • Insert the rotor shaft in the ball bearing.
    • As seen in the video, lift brushes' wires: this helps the brush moving flawlessly in the brusholder.
    • This operation is very important: if you forget to do this the wire may clamp in the o-ring sealing and prevent the brush from moving towards the electrical rotary joint. Waterproofness is also compromised, if this happens.
    • Come back here if you assembled everythinng but the motor won't turn on after applying power.
  3. Marco UP Series Electric Pump Assembly, Insert the stator tube: étape 5, image 1 de 3 Marco UP Series Electric Pump Assembly, Insert the stator tube: étape 5, image 2 de 3 Marco UP Series Electric Pump Assembly, Insert the stator tube: étape 5, image 3 de 3
    • Place the stator tube over the rotor.
    • Make sure that the MARCO logo stays upward, otherwise the pump rotates in the wrong direction.
    • With your thumb, keep the rotor down. The magnetic field is strong and tries to lift it up: if it happens, you have to set the brushes back in place, like in the previous steps.
    • Make sure that the brushes' wires are in place!
  4. Marco UP Series Electric Pump Assembly, If it doesn't work the first time...: étape 6, image 1 de 2 Marco UP Series Electric Pump Assembly, If it doesn't work the first time...: étape 6, image 2 de 2
    • If you didn't manage to stop the rotor from lifting, pull it out from the stator tube by pulling from the top and pushing from the bottom.
    • Once you have both of them divided, start all over again.
    • Don't try to force the rotor between the brushes without unloading the brushes' springs! You may break them.
  5. Marco UP Series Electric Pump Assembly, Insert the pump head: étape 7, image 1 de 3 Marco UP Series Electric Pump Assembly, Insert the pump head: étape 7, image 2 de 3 Marco UP Series Electric Pump Assembly, Insert the pump head: étape 7, image 3 de 3
    • Make sure that the pump's brusholder is in the correct position, like in the first picture. You should have the cables looking down on the right and the MARCO logo in the sticker on the stator that looks toward pump's head.
    • Insert the pump's head tie-rods in the holes between the magnets.
    • There's only one way to mount it right, the other is upside down! Watch the pictures.
    • Push the tie-rods down to the end of the motor: they should come out on the other side, as seen in the next steps.
    • The smaller motors have the tie-rods placed horizontally: refer to the position of the holes in the pump's head to understand the right direction to assembly them!
  6. Marco UP Series Electric Pump Assembly, Fix the nuts: étape 8, image 1 de 3 Marco UP Series Electric Pump Assembly, Fix the nuts: étape 8, image 2 de 3 Marco UP Series Electric Pump Assembly, Fix the nuts: étape 8, image 3 de 3
    • First insert the o-rings.
    • Then add the washers.
    • Eventually, close slightly with the nuts.
    • Before screwing firmly the nuts, shake a little the assembly or allow a few kicks with a soft mallet on the back of the pump, to adjust the mechanical parts to each other.
    • If you can, test that the motor rotates freely by connecting it to the power supply right now. This is a useful step to do right now, because if the brushes are not correctly assembled, you'll have to disassembly the pump again e start from step 4.
    • Firmly fix the nuts, but be prepared to untighten them as needed if the pump draws too much current.
  7. Marco UP Series Electric Pump Assembly, Insert the key: étape 9, image 1 de 3 Marco UP Series Electric Pump Assembly, Insert the key: étape 9, image 2 de 3 Marco UP Series Electric Pump Assembly, Insert the key: étape 9, image 3 de 3
    • Turn the pump around and insert gear's key in the shaft.
    • This may be tricky on the smaller pumps: if you haven't enough room to slide it inside with the finger like in the pictures, you may use a magnetic flat screwdriver if you have a metal key or a flat screwdriver with some grease on it to make it sticky for the plastic ones.
  8. Marco UP Series Electric Pump Assembly, Add the gears: étape 10, image 1 de 3 Marco UP Series Electric Pump Assembly, Add the gears: étape 10, image 2 de 3 Marco UP Series Electric Pump Assembly, Add the gears: étape 10, image 3 de 3
    • First, insert the gear with the key: it could be harder to do it once the other gear is in place.
    • Then, insert the second gear.
    • Follow the movements in the video to insert the o-ring in its slot.
    • Watch the flow direction arrow on the sticker, and place the top plate as shown.
  9. Marco UP Series Electric Pump Assembly, Lock the top plate with the screws: étape 12, image 1 de 3 Marco UP Series Electric Pump Assembly, Lock the top plate with the screws: étape 12, image 2 de 3 Marco UP Series Electric Pump Assembly, Lock the top plate with the screws: étape 12, image 3 de 3
    • Don't close them too tight, the screwdriver strength is ok!
  10. Marco UP Series Electric Pump Assembly, All done!: étape 13, image 1 de 1
    • Your pump is assembly is completed!
    • If it draws too much current loose the screws on the top plate (a little) with the motor spinning and/or the nuts on the back. Allow a few seconds free spin and close them again. This helps the different parts to adjust correctly to the working position.
Ligne d'arrivée
9 autres ont terminé cette réparation.
Marco Spa
Membre depuis le 12/04/15
1 501 Réputation
5 tutoriels rédigés
6 commentaires
I have a Marco Pump UP6 Gear Pump 12v.
But it is not running...
Has any fuse inside?
yanis - Réponse
If it’s not running, the brushes have been placed incorrectly, they have to be able to move freely in the brush-holder and they have to touch the commutator!
Marco Spa -
Marco Spa, I have a UP3/oil. When I put the port adapters on and the next adapters (3/8 > 5/8flr) then my AN10 hose fittings it all becomes too wide. I wish to make special adapters from the pump body direct to AN10. Can you please tell me the thread size of the pump body? It looks like 17x1.5mm but I wish to be very sure.
Gracie Mille
Ed LLorca
Ed LLorca - Réponse
Hi! The pump body follows the G 3/8"-19 ISO 228 specification.
Marco Spa -
¿Cuanto tiempo pueden funcionar en continuo la UP9/ OIL? y¿ cuanto tiempo de descanso para que se recupere?
Miguel angel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 124
Total : 6,049
