Aller au contenu principal
Marshall Emberton Battery Replacement
Ce dont vous avez besoin
  1. Marshall Emberton Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the rubber casing from the speaker using your nails to peel the cover off.
  2. Marshall Emberton Battery Replacement: étape 2, image 1 de 1
    • Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
  3. Marshall Emberton Battery Replacement: étape 3, image 1 de 2 Marshall Emberton Battery Replacement: étape 3, image 2 de 2
    • Use a TR9 screwdriver to remove the eight 1.2 cm screws.
    • Use a spudger or opening tool to pry out the speakers.
  4. Marshall Emberton Battery Replacement: étape 4, image 1 de 1
    • Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
  5. Marshall Emberton Battery Replacement: étape 5, image 1 de 2 Marshall Emberton Battery Replacement: étape 5, image 2 de 2
    • Disconnect the three wire connectors marked, by firmly tugging on the wire.
  6. Marshall Emberton Battery Replacement: étape 6, image 1 de 1
    • Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
Asia Baldwin
Membre depuis le 09/26/22
697 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 membres
5 tutoriels rédigés
2 commentaires
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
Yamilena Hernandez - Réponse
How can i buy battery
Rubel hussain - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 116
30 derniers jours : 530
Total : 5,733
