Aller au contenu principal
Marshall Uxbridge LED Board Replacement
Ce dont vous avez besoin
  1. Marshall Uxbridge LED Board Replacement, Back Panel: étape 1, image 1 de 3 Marshall Uxbridge LED Board Replacement, Back Panel: étape 1, image 2 de 3 Marshall Uxbridge LED Board Replacement, Back Panel: étape 1, image 3 de 3
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
  2. Marshall Uxbridge LED Board Replacement: étape 2, image 1 de 2 Marshall Uxbridge LED Board Replacement: étape 2, image 2 de 2
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
  3. Marshall Uxbridge LED Board Replacement: étape 3, image 1 de 1
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
  4. Marshall Uxbridge LED Board Replacement, LED Board: étape 4, image 1 de 2 Marshall Uxbridge LED Board Replacement, LED Board: étape 4, image 2 de 2
    • Orient the bottom of the speaker to face away from you.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws holding the power relay in place.
  5. Marshall Uxbridge LED Board Replacement: étape 5, image 1 de 2 Marshall Uxbridge LED Board Replacement: étape 5, image 2 de 2
    • Separate the power relay from the speaker.
    • Slide out the blue ribbon cable from the power relay.
    • Put the power relay to the side.
  6. Marshall Uxbridge LED Board Replacement: étape 6, image 1 de 1
    • Remove the two 6 mm screws connected to the LED board using a TR9 Torx screwdriver.
  7. Marshall Uxbridge LED Board Replacement: étape 7, image 1 de 2 Marshall Uxbridge LED Board Replacement: étape 7, image 2 de 2
    • Pull the blue ribbon cable to lift the LED board.
    • Pull the blue ribbon cable out of the LED board.
Angie Delgado
Membre depuis le 09/06/24
390 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 21
Total : 55
