Aller au contenu principal
Marshall Woburn Back Panel Replacement
Ce dont vous avez besoin
  1. Marshall Woburn Back Panel Replacement, Back Panel: étape 1, image 1 de 2 Marshall Woburn Back Panel Replacement, Back Panel: étape 1, image 2 de 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Back Panel Replacement: étape 2, image 1 de 2 Marshall Woburn Back Panel Replacement: étape 2, image 2 de 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Back Panel Replacement: étape 3, image 1 de 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
NateP
Membre depuis le 11/01/23
281 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 35
Total : 411
