Aller au contenu principal
Marshall Woburn I/O Board Replacement
Ce dont vous avez besoin
  1. Marshall Woburn I/O Board Replacement, Back Panel: étape 1, image 1 de 2 Marshall Woburn I/O Board Replacement, Back Panel: étape 1, image 2 de 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn I/O Board Replacement: étape 2, image 1 de 2 Marshall Woburn I/O Board Replacement: étape 2, image 2 de 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn I/O Board Replacement: étape 3, image 1 de 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn I/O Board Replacement, I/O Board: étape 4, image 1 de 1
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
  5. Marshall Woburn I/O Board Replacement: étape 5, image 1 de 2 Marshall Woburn I/O Board Replacement: étape 5, image 2 de 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn I/O Board Replacement: étape 6, image 1 de 1
    • Completely remove the I/O board and the attached plate.
Ryan Berry
Membre depuis le 10/31/23
237 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 membres
6 tutoriels rédigés
Un commentaire
what is step 7? Replace the board? PS. I was born in N Dartmouth!
Mary F Boston - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 37
Total : 828
