Introduction
This guide will illustrate how to replace the analog battery in the Martian Victory watch.
It is very important to tell your users to use the correct tool for the job. Metal spudgers and screwdrivers can damage delicate internal components and puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
Ce dont vous avez besoin
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
2 autres ont terminé cette réparation.
3 commentaires
I am researching for methods to change batteries on a watch. Would like to thank you for this piece. It is really good. However, you have used some tools in your tutorial. but since they pins and scissors are in everyone's home, making your way easy
I shall be writing a post in the same topic. and would love to feature your guide on it..
Thanks
Ronald Mckim
Owner: http://www.mywatchvilla.com/
@ronaldmckim, you may embed our guide using the instructions here: https://ifixit.org/blog/8474/embed-guide.... For our content licensing policies, see: Content Licensing.
Hi.. Thank you for the detailed steps, it really helped a lot in replacing the analog battery ourselves
However, now we are not able to place the mother board back in its place, hence wanted to check if there is any tips or steps or screenshots how we can place it back?
