Aller au contenu principal
Martian Victory LED Screen Replacement
Ce dont vous avez besoin
  1. Martian Victory LED Screen Replacement, Back Plate: étape 1, image 1 de 2 Martian Victory LED Screen Replacement, Back Plate: étape 1, image 2 de 2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: étape 2, image 1 de 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: étape 3, image 1 de 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: étape 4, image 1 de 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: étape 5, image 1 de 1
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: étape 6, image 1 de 1
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: étape 7, image 1 de 1
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: étape 8, image 1 de 1
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: étape 9, image 1 de 2 Martian Victory LED Screen Replacement: étape 9, image 2 de 2
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: étape 10, image 1 de 2 Martian Victory LED Screen Replacement: étape 10, image 2 de 2
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: étape 11, image 1 de 1
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
Robert Sanchez
Membre depuis le 10/31/16
201 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 10
Total : 202
