Aller au contenu principal
Martian Victory Motherboard Replacement
Ce dont vous avez besoin
  1. Martian Victory Motherboard  Replacement, Back Plate: étape 1, image 1 de 2 Martian Victory Motherboard  Replacement, Back Plate: étape 1, image 2 de 2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: étape 2, image 1 de 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: étape 3, image 1 de 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: étape 4, image 1 de 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: étape 5, image 1 de 1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: étape 6, image 1 de 1
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: étape 7, image 1 de 1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: étape 8, image 1 de 3 Martian Victory Motherboard  Replacement: étape 8, image 2 de 3 Martian Victory Motherboard  Replacement: étape 8, image 3 de 3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: étape 9, image 1 de 2 Martian Victory Motherboard  Replacement: étape 9, image 2 de 2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
Dominic Coffey
Membre depuis le 10/24/16
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 11
Total : 189
