Aller au contenu principal
Master and Dynamic MW50 Battery Replacement
Ce dont vous avez besoin
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 1 de 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 2 de 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 3 de 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: étape 2, image 1 de 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: étape 3, image 1 de 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: étape 4, image 1 de 2 Master and Dynamic MW50 Battery Replacement, Battery: étape 4, image 2 de 2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: étape 5, image 1 de 1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: étape 6, image 1 de 2 Master and Dynamic MW50 Battery Replacement: étape 6, image 2 de 2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
Tyler Guffey
Membre depuis le 01/24/19
208 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S1-G4, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 membres
12 tutoriels rédigés
Un commentaire
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 55
Total : 1,451
