Aller au contenu principal
Matsunichi M97 9 inch Speaker Replacement
Ce dont vous avez besoin
  1. Matsunichi M97 9 inch Speaker Replacement, Battery: étape 1, image 1 de 1
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Speaker Replacement: étape 2, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Speaker Replacement: étape 3, image 1 de 3 Matsunichi M97 9 inch Speaker Replacement: étape 3, image 2 de 3 Matsunichi M97 9 inch Speaker Replacement: étape 3, image 3 de 3
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Speaker Replacement: étape 4, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Speaker Replacement: étape 5, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 5, image 2 de 2
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Speaker Replacement, Motherboard: étape 6, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement, Motherboard: étape 6, image 2 de 2
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Speaker Replacement: étape 7, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 7, image 2 de 2
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Speaker Replacement: étape 8, image 1 de 1
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Speaker Replacement: étape 9, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 9, image 2 de 2
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Speaker Replacement: étape 10, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 10, image 2 de 2
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Speaker Replacement: étape 11, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 11, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Speaker Replacement: étape 12, image 1 de 1
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Speaker Replacement: étape 13, image 1 de 2 Matsunichi M97 9 inch Speaker Replacement: étape 13, image 2 de 2
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Speaker Replacement, Speaker: étape 14, image 1 de 1
    • Unsolder speakers from motherboard, removing both wires separately and one at a time.
    • Not a lot of solder is present - not a lot is necessary; therefore, using too much or not working quickly can result in permanent damage to the device.
    • For more information on soldering, please read the How to Solder and Desolder Connections guide.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 72
