Aller au contenu principal
Mattel Barbie Boombox BE-466 Antenna Replacement
Ce dont vous avez besoin
  1. Mattel Barbie Boombox BE-466 Antenna Replacement, Antenna: étape 1, image 1 de 2 Mattel Barbie Boombox BE-466 Antenna Replacement, Antenna: étape 1, image 2 de 2
    • Flip radio upside down.
    • This radio is missing the lid for the battery compartment. If you have a battery cover, you must use a screwdriver to remove the screws before you can take off the cover.
    • Remove the batteries.
  2. Mattel Barbie Boombox BE-466 Antenna Replacement: étape 2, image 1 de 1
    • Flip radio so the back facing up.
    • The radio shown is missing the power cord. The power cord is a black cord attached to the back.
    • Unplug power cord.
  3. Mattel Barbie Boombox BE-466 Antenna Replacement: étape 3, image 1 de 2 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 3, image 2 de 2
    • Flip the radio over so the bottom of the radio is facing up.
    • Insert the Philips #2 screwdriver into the antenna screw hole.
  4. Mattel Barbie Boombox BE-466 Antenna Replacement: étape 4, image 1 de 3 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 4, image 2 de 3 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 4, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the screw securing the antenna.
    • Remove the antenna.
    • Use tweezers/pliers if your antenna is broken off or too short to hold.
  5. Mattel Barbie Boombox BE-466 Antenna Replacement: étape 5, image 1 de 2 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 5, image 2 de 2
    • Insert the new antenna into the antenna hole on top of the device.
  6. Mattel Barbie Boombox BE-466 Antenna Replacement: étape 6, image 1 de 3 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 6, image 2 de 3 Mattel Barbie Boombox BE-466 Antenna Replacement: étape 6, image 3 de 3
    • The new antenna is slightly bigger than the original. Use a 2.5mm x 8mm Phillips screw instead of the original screw.
    • Hold the antenna and insert the screw into the antenna screw hole.
    • Use the Phillips #2 screwdriver to secure the screw.
To reassemble your device, follow steps 1 and 2 in reverse order.
Sarah Nguyen
Membre depuis le 04/25/24
133 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-4, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 4-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G4
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 72
