Aller au contenu principal
Maylong MN-1000P Battery Replacement
Ce dont vous avez besoin
  1. Maylong MN-1000P Battery Replacement, Bottom Cover: étape 1, image 1 de 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Battery Replacement: étape 2, image 1 de 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Battery Replacement: étape 3, image 1 de 3 Maylong MN-1000P Battery Replacement: étape 3, image 2 de 3 Maylong MN-1000P Battery Replacement: étape 3, image 3 de 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Battery Replacement: étape 4, image 1 de 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Battery Replacement: étape 5, image 1 de 1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Battery Replacement, Battery: étape 6, image 1 de 2 Maylong MN-1000P Battery Replacement, Battery: étape 6, image 2 de 2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
katelyn buckman
Membre depuis le 01/13/20
553 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 9
Total : 205
