Aller au contenu principal
Maylong MN-1000P Button Panel Replacement
Ce dont vous avez besoin
  1. Maylong MN-1000P Button Panel Replacement, Bottom Cover: étape 1, image 1 de 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Button Panel Replacement: étape 2, image 1 de 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Button Panel Replacement: étape 3, image 1 de 3 Maylong MN-1000P Button Panel Replacement: étape 3, image 2 de 3 Maylong MN-1000P Button Panel Replacement: étape 3, image 3 de 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Button Panel Replacement: étape 4, image 1 de 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Button Panel Replacement: étape 5, image 1 de 1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Button Panel Replacement, Battery: étape 6, image 1 de 2 Maylong MN-1000P Button Panel Replacement, Battery: étape 6, image 2 de 2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
  7. Maylong MN-1000P Button Panel Replacement, Screen: étape 7, image 1 de 1
    • Remove the six 6mm Phillips #00 screws from both sides of the netbook.
  8. Maylong MN-1000P Button Panel Replacement: étape 8, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 8, image 2 de 2
    • Pull the top of the computer and the back side of the computer away from each other until they are detached.
    • Flip the entire computer over so you can see both the screen and keyboard.
  9. Maylong MN-1000P Button Panel Replacement: étape 9, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 9, image 2 de 2
    • Remove all the black circular pads from around the screen.
    • Remove all 6mm Phillips #00 screws from around the screen bezel.
  10. Maylong MN-1000P Button Panel Replacement: étape 10, image 1 de 1
    • Using a plastic opening tool, pry off the screen bezel.
    • After detaching the screen bezel, pull up on the bezel near the hinge area.
  11. Maylong MN-1000P Button Panel Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
  12. Maylong MN-1000P Button Panel Replacement: étape 12, image 1 de 1
    • Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
  13. Maylong MN-1000P Button Panel Replacement: étape 13, image 1 de 3 Maylong MN-1000P Button Panel Replacement: étape 13, image 2 de 3 Maylong MN-1000P Button Panel Replacement: étape 13, image 3 de 3
    • Detach the wide yellow ribbon cable connected to the screen from the computer.
  14. Maylong MN-1000P Button Panel Replacement: étape 14, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 14, image 2 de 2
    • Flip the computer over.
    • Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
  15. Maylong MN-1000P Button Panel Replacement: étape 15, image 1 de 3 Maylong MN-1000P Button Panel Replacement: étape 15, image 2 de 3 Maylong MN-1000P Button Panel Replacement: étape 15, image 3 de 3
    • Remove the black tape holding down the red, green, black, and white intertwined wires.
    • Remove the screen.
  16. Maylong MN-1000P Button Panel Replacement, Motherboard: étape 16, image 1 de 1
    • Remove the six 6mm Phillips #00 screws from the motherboard.
  17. Maylong MN-1000P Button Panel Replacement: étape 17, image 1 de 1
    • Remove the two 6mm silver screws from the small circuit board connected to the motherboard by the red and black wires.
  18. Maylong MN-1000P Button Panel Replacement: étape 18, image 1 de 1
    • Remove the two small black speakers on the corners connected to the motherboard by the black and red wires.
  19. Maylong MN-1000P Button Panel Replacement: étape 19, image 1 de 1
    • Disconnect the black connectors from the motherboard by pulling on the white ribbon cable.
  20. Maylong MN-1000P Button Panel Replacement: étape 20, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 20, image 2 de 2
    • Remove the black covered wire connected to the motherboard by pulling the white ribbon cable away from the motherboard.
  21. Maylong MN-1000P Button Panel Replacement: étape 21, image 1 de 1
    • Using a spudger, remove the gold cylinder out of the indent at the bottom of the computer.
  22. Maylong MN-1000P Button Panel Replacement: étape 22, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 22, image 2 de 2
    • Lift the motherboard up.
    • Remove the motherboard by detaching the clear tape from underneath the motherboard.
  23. Maylong MN-1000P Button Panel Replacement, Button Panel: étape 23, image 1 de 1
    • Remove the four 6mm Phillips #00 screws from the button panel.
  24. Maylong MN-1000P Button Panel Replacement: étape 24, image 1 de 2 Maylong MN-1000P Button Panel Replacement: étape 24, image 2 de 2
    • Lift up the button panel and replace.
katelyn buckman
Membre depuis le 01/13/20
553 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 62
