Aller au contenu principal
Maytag MF D2561KES Water Filter Replacement
Ce dont vous avez besoin
  1. Maytag MF D2561KES Water Filter Replacement, Water Filter: étape 1, image 1 de 2 Maytag MF D2561KES Water Filter Replacement, Water Filter: étape 1, image 2 de 2
    • Locate your water filter in the fridge.
    • On this fridge, it will be located above the top shelf on the right hand side.
  2. Maytag MF D2561KES Water Filter Replacement: étape 2, image 1 de 2 Maytag MF D2561KES Water Filter Replacement: étape 2, image 2 de 2
    • Make sure that the water filter you purchased is recommended for your refrigerator brand.
    • Open the filter container. using the push button
  3. Maytag MF D2561KES Water Filter Replacement: étape 3, image 1 de 2 Maytag MF D2561KES Water Filter Replacement: étape 3, image 2 de 2
    • Twist the filter slightly to the right.
    • It is important that this is done gently, since it could be easily broken.
  4. Maytag MF D2561KES Water Filter Replacement: étape 4, image 1 de 1
    • Remove the old water filter and drain the excess water in the filter into the sink.
    • The filter could be disposed by being placed in the regular garbage.
    • Extra water should be dumped into the sink before it is thrown away.
  5. Maytag MF D2561KES Water Filter Replacement: étape 5, image 1 de 2 Maytag MF D2561KES Water Filter Replacement: étape 5, image 2 de 2
    • Install the new water filter by screwing it into the nozzle.
    • Twist in the opposite direction that you used to take out the filter.
  6. Maytag MF D2561KES Water Filter Replacement: étape 6, image 1 de 3 Maytag MF D2561KES Water Filter Replacement: étape 6, image 2 de 3 Maytag MF D2561KES Water Filter Replacement: étape 6, image 3 de 3
    • Place the new filter back in the containment unit.
    • Make sure it it tight and the top is closed for the filter to work properly.
    • Throw out the first tray of ice made after changing the filter.
  7. Maytag MF D2561KES Water Filter Replacement: étape 7, image 1 de 2 Maytag MF D2561KES Water Filter Replacement: étape 7, image 2 de 2
    • Get a large container and press the water button and hold it for roughly 60 seconds.
    • Make sure to dump this water in the sink, since it would be not safe to drink.
    • After the water has been run for 60 seconds the water is again filtered and ready to drink.
    • It should make a odd sound when used for the first time. This is perfectly normal, and will stop making that sound after the first time it is used. It is air in the system and will stop once the water filter is full of water.
Here is how you can replace a water filter for a refrigerator. Removing the filter could just use the first 4 steps.
Rocco Ali
Membre depuis le 05/10/21
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G1, O'Regan Summer 2021 Membre de l'équipe York University, Team S1-G1, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 22
Total : 622
