Aller au contenu principal
Maze Speed SSB-508 Speaker and Microphone Replacement
Ce dont vous avez besoin
  1. Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: étape 1, image 1 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: étape 1, image 2 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: étape 1, image 3 de 3
    • With the phone face down, remove the back cover with the plastic opening tool. For easiest access, insert the plastic opening tool in the bottom left corner.
  2. Maze Speed SSB-508 Speaker and Microphone Replacement: étape 2, image 1 de 1
    • After the back cover is removed, remove the battery, sim cards, and micro SD card. These components are highlighted in red.
  3. Maze Speed SSB-508 Speaker and Microphone Replacement: étape 3, image 1 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement: étape 3, image 2 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement: étape 3, image 3 de 3
    • Using the screwdriver, remove fourteen 2mm screws to access the internal casing of the phone.
    • After the screws are removed, use the plastic opening tool to remove the internal casing cover.
  4. Maze Speed SSB-508 Speaker and Microphone Replacement: étape 4, image 1 de 2 Maze Speed SSB-508 Speaker and Microphone Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Locate the wire that attaches the motherboard to the daughter-board of the speaker and mic. Using tweezers, disconnect the wire from the motherboard.
  5. Maze Speed SSB-508 Speaker and Microphone Replacement: étape 5, image 1 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement: étape 5, image 2 de 3 Maze Speed SSB-508 Speaker and Microphone Replacement: étape 5, image 3 de 3
    • Using your soldering tools, un-solder both set of wires that are connected to the daughter-board.
    • You may now replace the old speaker and mic with new accessories.
Bryce Stewart
Membre depuis le 07/09/19
121 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 804
