Ce dont vous avez besoin
Turn the clock radio over so the bottom is facing up.
Pull the tab upward and remove the cover from the battery compartment.
Remove the batteries.
Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
Deolder the antenna wire from the circuit board, and remove the wire.
Presque terminé !
