Introduction
These steps will instruct you on removing a broken spring and replace it with a new one.
  1. Locate the 'OPEN' tab on the battery compartment. Pull the tab upwards and remove the cover using your finger. Remove the batteries.
    • Locate the 'OPEN' tab on the battery compartment.
    • Pull the tab upwards and remove the cover using your finger.
    • Remove the batteries.
  2. Locate the screws on the bottom of the device that hold the upper and lower halves together. Remove the (5) 19mm screws. Grasp the top and bottom and gently pull apart.
    • Locate the screws on the bottom of the device that hold the upper and lower halves together.
    • Remove the (5) 19mm screws.
    • Grasp the top and bottom and gently pull apart.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Remove screw with plastic retaining plastic piece. Remove screw with plastic retaining plastic piece.
    • Remove screw with plastic retaining plastic piece.
  5. Grasp and remove the spring using fine tip tweezers. The spring is very small and can be lost easily. The spring is very small and can be lost easily.
    • Grasp and remove the spring using fine tip tweezers.
    • The spring is very small and can be lost easily.
  6. Remove the spring with a flat tip screwdriver. Remove the spring with a flat tip screwdriver.
    • Remove the spring with a flat tip screwdriver.
Aubrey Frank
Membre depuis le 15/02/2018
393 Réputation
4 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 64
