Introduction
If the Minimove is not turning on when new batteries are used, the battery wires may have come loose or disconnected. With this guide, you will replace the battery wires for the Minimove by soldering. For more information on soldering reference the iFixit soldering guide.
Ce dont vous avez besoin
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the motherboard and daughterboard are free.
Outil utilisé dans cette étape :Desoldering Pump$3.99
After detaching the wire, move it away from the device.
Use a desoldering pump while the solder is still liquid to remove excess solder.
3 autres ont terminé cette réparation.
