Aller au contenu principal
Mend a tear at the knee, by hand, with no-waste patch. Replacement
  1. Mend a tear at the knee, by hand, with no-waste patch. Replacement, Mend a tear at the knee with no-waste patch.: étape 1, image 1 de 1
    • For this mend you’ll need a pair of scissors, sewing needle, sewing thread, pins and a seam-ripper(sharp scissors can also work).
  2. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 2, image 1 de 1
    • Begin by removing the seams of the back pocket that you wish to use as a knee patch. Some pockets have asymmetrical shapes; these have one bottom corner slightly lower than the other, which mirrors the other pocket. If you have a preference, keep that in mind when you choose which pocket goes on which knee.
  3. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 3, image 1 de 2 Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 3, image 2 de 2
    • You can undo the seam in different ways:
    • 1) From the front as shown in the photo on the previous step. 2) From between the fabrics, by pulling gently on the pocket seam to reveal the thread underneath. 3) From the inside if the jeans.
    • Choose whichever works best for you. Consider, where is the thread most visible? Where is it easiest to pick up the thread with the ripper or scissors and cut it? Often, alternating is needed.
  4. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 4, image 1 de 1
    • Try to remove as much of the cut thread as possible to make the patch clean and easy to work with.
  5. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 5, image 1 de 2 Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 5, image 2 de 2
    • Try to find the grain in the fabrics — the lines that indicate the threads of the woven denim — and align the patch and the leg as much as possible. (The altered picture is from another project.)
    • Secure the pocket-patch over the damaged knee area by pinning it in place.
  6. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 6, image 1 de 1
    • Thread your needle with a ca 70 cm long thread. Tie a knot at the end; often multiple knots on top of each other are needed to stop the thread from escaping through the fabric.
    • If the length of the thread is cumbersome, try to place the needle more toward the middle of the thread so it kind of looks like you’re working with a double thread. As you work and the thread becomes shorter, then you can shift the needle along the length of the thread.
    • However, do NOT leave the extra thread in the actual stitches; you will not easily be able to pull it out again.
  7. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 7, image 1 de 1
    • Apply the first stitch by pulling the needle through the fabric from the back of the pocket-patch but above the base jeans fabric. This will ensure that the knot will be safe between the fabrics when the stitching is complete, and also ensure that the knot will not disturb the skin of the user afterwards.
    • Keep the stitches close to the edge, ideally along the original seam. The tighter/shorter the stitches, the more stable the mend will be. The easiest stitches would probably be running stitches (just up and down, like a dolphin jumping at the surface of the water), or backstitch (10 mm forward, 5 mm back).
  8. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 8, image 1 de 3 Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 8, image 2 de 3 Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 8, image 3 de 3
    • After stitching along the entire edge of the pocket patch, fasten the thread by doing several small stitches in place, and finish by pulling the needle down from the fastening stitches into the space between the fabric layers, creating a long stitch/dive to hide and secure the end of the thread.
    • Lastly, cut the thread along the fabric surface.
  9. Mend a tear at the knee, by hand, with no-waste patch. Replacement: étape 9, image 1 de 1
    • Finished: mended knee tear with no-waste patch.
    • If you like, you can do the same to the other knee to match the look.
Ligne d'arrivée
Susanne Goding
Membre depuis le 03/14/24
169 Réputation
1 tutoriel rédigé
Équipe
Repair Café Malmö Membre de l'équipe Repair Café Malmö
Community
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 11
