Aller au contenu principal
Merangue Steel 3-Hole Punch Head Replacement
Ce dont vous avez besoin
  1. Merangue Steel 3-Hole Punch Head Replacement, Punch Head: étape 1, image 1 de 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: étape 1, image 2 de 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: étape 1, image 3 de 3
    • Tilt the hole puncher on its back.
    • Use a flathead screwdriver to remove the three screws.
  2. Merangue Steel 3-Hole Punch Head Replacement: étape 2, image 1 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 2, image 2 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 2, image 3 de 3
    • Use your finger to slide the punch head out towards the opening (right in this case).
    • Remove the punch head from the opening and set it aside.
    • Repeat this step with the other punch heads.
  3. Merangue Steel 3-Hole Punch Head Replacement: étape 3, image 1 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 3, image 2 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 3, image 3 de 3
    • Take your replacement hole punch and push it into the opening.
    • Slide the hole punch to your desired alignment in my case, left).
    • Make sure the hole punch is properly aligned (the hole at the back should point directly at the ceiling).
  4. Merangue Steel 3-Hole Punch Head Replacement: étape 4, image 1 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 4, image 2 de 3 Merangue Steel 3-Hole Punch Head Replacement: étape 4, image 3 de 3
    • Use your fingers to screw one of the screws into the hole on the back of the punch head.
    • The screw can be a bit difficult to align so be patient and don't rush.
    • Take your flat head screwdriver and tighten the screw.
    • Repeat these steps for the other punch heads.
Ligne d'arrivée
Noah Dela Calzada
Membre depuis le 01/16/24
109 Réputation
1 tutoriel rédigé
Équipe
York University, Team P-6, O'Regan Winter 2024 Membre de l'équipe York University, Team P-6, O'Regan Winter 2024
YORK-O'REGAN-W24SPG6
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 51
