Aller au contenu principal
Mercedes W123 Battery Ground Cable Replacement
Ce dont vous avez besoin
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: étape 1, image 1 de 2 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: étape 1, image 2 de 2
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: étape 2, image 1 de 1
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: étape 3, image 1 de 2 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: étape 3, image 2 de 2
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
  4. Mercedes W123 Battery Ground Cable Replacement: étape 4, image 1 de 1
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
12 autres ont terminé cette réparation.
Nicolas Siemsen
Membre depuis le 12/06/13
39 040 Réputation
79 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 530 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 40
Total : 8,829
