Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mercedes W123 Climate Control Unit v2 Replacement
Ce dont vous avez besoin
    1. Mercedes W123 Climate Control Unit v2 Replacement, Climate Control Unit v2: étape 1, image 1 de 1
      • To assist with identification, this is what the second generation climate control push button panel looks like in the W123. If yours looks like this, this guide is for you.
      • To begin, carefully pry off the wood trim covering the front panel of the climate control unit. Use a plastic pry tool or a flat head screw driver. See the wood trim replacement guide for some additional tips.
      Demander à FixBot
      Ajouter un commentaire
    2. Mercedes W123 Climate Control Unit v2 Replacement: étape 2, image 1 de 1
      • Next, remove the two screws in the upper corners of the panel behind the wood trim.
      Demander à FixBot
    3. Mercedes W123 Climate Control Unit v2 Replacement: étape 3, image 1 de 1
      • Then pull out the panel first with a pry tool or flat head screw driver, then your fingers. Only pry until you get some light resistance from the tabs at the bottom. Then, you'll need to lift up as you continue to pull out until you get the plastic tabs to clear the bottom edge.
      • Then remove the three screws around the buttons on the panel to remove the front panel from the control unit.
      Demander à FixBot
    4. Mercedes W123 Climate Control Unit v2 Replacement: étape 4, image 1 de 3 Mercedes W123 Climate Control Unit v2 Replacement: étape 4, image 2 de 3 Mercedes W123 Climate Control Unit v2 Replacement: étape 4, image 3 de 3
      • With the front panel removed you will be left with just the control unit itself.
      • Gently pull on the four light bulb holders that plug in to the top of the unit to remove them.
      Demander à FixBot
    5. Mercedes W123 Climate Control Unit v2 Replacement: étape 5, image 1 de 3 Mercedes W123 Climate Control Unit v2 Replacement: étape 5, image 2 de 3 Mercedes W123 Climate Control Unit v2 Replacement: étape 5, image 3 de 3
      • Then pull off the two large plugs, one on each side of the control unit. Don't pull or pry too hard or you risk pulling the cover off the back of the plugs instead, potentially sending wires everywhere! Just take your time and wiggle them off gently.
      • You can now remove the control unit and perform any work on it you need to (re-soldering of cold joints, for example) or you can install a refurbished unit like the Programa unit pictured.
      Demander à FixBot
15 autres ont terminé cette réparation.
Nicolas Siemsen
Membre depuis le 12/06/13
40 559 Réputation
79 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
335 membres
8 260 tutoriels rédigés
5 commentaires de tutoriel
Where can I see a better picture of the Programa unit and where to buy it. Will a refurbished unit assure correcting the malfunctions of the old unit being replaced?
The problem I have is whenever I need AC, sometimes just pressing cold air (center) button will either not respond (as if nothing happens next) at all or run with hot air. But if I first press the leftmost (defrost) button then ASAP pressing the cold air button will engage the AC. It is as if a push was needed to kickstart the cold air (center) button. During these steps the button is on the low or auto position and the thermostat dial is set at max (blue) position.
So, does this mean that my controls unit is defective and have to be replaced with a refurbished Programa unit to operate correctly?
I am the original owner of this '84 300D and have never repaired this unit before. Perhaps if I apply contact spray to the elect. connectors the buttons will have restored stronger contact.
Bobby De Jesus - Réponse Partager
Do you have a guide for the older model (pre-81 W123) climate control unit?
slapcat - Réponse Partager
You didn’t say how to open the push button unit so joints could be checked & resoldered.
Graham Moss - Réponse Partager
You are right! That is because this guide is on how to remove and replace the unit. Not how to fix it. That would be a much much longer guide. There are other resources online that cover some of the options. Google will help.
Nicolas Siemsen - Réponse Partager
Hi! one additional thing I'd advise is before installing a new working pushbutton unit, an inline fuse must be installed in the auxillary water pump wire. If this seizes, it WILL overload the hvac control board. I had this exact unit, I repaired it, and the pump seized causing an open fire inside the dash of the car. I was lucky to catch it before it destroyed more than the hvac components
Alexander P - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 43
30 derniers jours : 120
Total : 18,616
