Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mercedes W123 Door Sill Disassembly
    1. Mercedes W123 Door Sill Disassembly, Sills or trims can: étape 1, image 1 de 2 Mercedes W123 Door Sill Disassembly, Sills or trims can: étape 1, image 2 de 2
      • The steps are the same for the 4 doors and the pieces are under pressure. Likewise, time can cause them to get stuck, you must proceed with care.
      • First we will have to open the door, and locate one of the corners, in which a plastic tool is inserted, with which we will travel the length of the piece to release it, this without forcing the piece.
      Demander à FixBot
      Ajouter un commentaire
    2. Mercedes W123 Door Sill Disassembly: étape 2, image 1 de 2 Mercedes W123 Door Sill Disassembly: étape 2, image 2 de 2
      • Once the previous step is done, introduce a second plastic tool (it can be a screwdriver covered with tape) on the inside of the piece, it must be inserted as close to the center of it, this is the side where we will exert leverage to release the piece. of its fit.
      • Firmly exert force, but without violence, making sure the piece does not flex too much, remember that it is old plastic. If necessary, pry both tools, making sure they are as far inside as possible.
      • You can use your hands once you have managed to lift one of the sides.
      Demander à FixBot
    3. Mercedes W123 Door Sill Disassembly: étape 3, image 1 de 2 Mercedes W123 Door Sill Disassembly: étape 3, image 2 de 2
      • This is the bottom side of the piece, it is simply embedded on the metal edge of the pressure door, and to place them simply position and press
      Demander à FixBot
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
es en
100%
HelloMacOS nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Carlos
Membre depuis le 03/09/18
993 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 53
Total : 2,176
