Introduction
The high-pressure power steering hose uses "field attachable" fittings (Gates). You can disassemble the fittings simply using box wrenches.
Ce dont vous avez besoin
Use an open-ended wrench or flare wrench (better) to unscrew the high-pressure tube nut (gold, inverted flare) from Vickers power steering pump. I found an 11/16" SAE wrench fit best.
Unscrew the tube nut from steering gear, using a 2nd wrench to keep the adapter in the gear from turning.
To remove each fitting, secure the outer shell in a vise or such. Use an open-ended wrench or flare wrench (better), to unscrew the mandrel tube from the ID of the hose. It is a normal right-hand thread. Once out, unscrew the hose from inside the shell. That is a left-hand thread, so turn as if you were tightening a bolt to unscrew.
Factory instructions for the fitting may be document "Gates Field Attachable Coupling Installation" (search), but note the shell there screws onto the hose OD with right-hand thread.
For high-pressure hose, I used SAE 100R5-8, 13/32" ID, 2000 psi, 1-wire (blue jacket). Cut w/ hacksaw or cut-off disk to 21" length.
A better choice might be SAE 100R3-6, 2 fiber braids, 3/8"ID, 0.75"OD, 1125 psi (Gates 6G3HXCTN), since more flexible and still adequate pressure. The factory hose had fibers, not steel wire.
For return, I used Parker 611HT-8, 1/2" ID, 400 psi (black jacket). Another choice is SAE 100R6, 1 fiber braid, 1/2" ID, 400 psi (Gates 8GTHXCTN).
Assembly is reverse order. Lubricate the hose OD and ID with power steering oil to make it easier.
Start screwing the new hose into the shell a few turns. It is a left-hand thread so turn ccw. As soon as you have room, push the tube mandrel into the hose ID and turn in 1 turn cw to get it started. Don't wait until the shell is all the way on or you may not be able to get the mandrel into the hose.
Continue screwing the shell onto the hose (ccw) until the end of the hose bottoms out in the shell, then unscrew 1/2 turn (cw). Then, continue screwing the mandrel into the hose ID until the mandrel bottoms out against the shell. Re-install hose on pump and gear, routing so it doesn't touch the car's body.
2 commentaires de tutoriel
Hi, I am currently in the process of changing my high pressure power steering line for Mercedes ml270 w163 2001... I was wondering if you could assist with any links or names to parts that may be of any help. The only part I can find online is 400 dollars.
No idea about your car. Some parts for cars are generic, like bearings, shaft seals, hoses, and belts. Sometimes you can find PN's (most bearings) to match. I have yet to find a rubber hose I couldn't replace from standard parts, though for AC hoses I had to buy the Mastercool crimper. Years ago, I took a power steering H.P. hose for my 1969 Dart to a local hydraulic shop in Atlanta and he made a new hose that matched from parts on the shelf, for only ~$10 in 1990 dollars. This M-B hose is one of the few that has re-usable fittings, also on the 1980's 300TD wagon self-leveling suspension hydraulic hoses. But even crimp-collar fittings, common in AC hoses can reused the fitting if you use a new collar (ferrule). In my M-B, I had to cut off the integral collar to re-use (like a Coll-O-Crimp).
