Aller au contenu principal
Mercedes-Benz 114 or 115 Auto shifter bushings
Ce dont vous avez besoin
Vidéo d'introduction
  1. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray: étape 1, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray: étape 1, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray: étape 1, image 3 de 3
    • This guide only applies to floor-shift automatics, such as my 1976 230.6 (114.015)
    • This car was never sold in USA, as I'm in New Zealand, but the centre-console is the same for all the other 114 and 115 automatics (and probably other model ranges)
    • First step is to open and remove your Ashtray to gain access to the first set of screws
    • Push down on the metal tab - while pulling the ashtray out
  2. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray frame: étape 2, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray frame: étape 2, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove Ashtray frame: étape 2, image 3 de 3
    • After you've removed the ashtray you'll see the ashtray frame/bracket
    • Remove the two pan-head screws at the rear of the opening - ignore the two counter-sunk screws at the bottom for now
    • Careful when you pull it out as the connector for the cigar lighter contacts on left sticks out so you can't just pull it straight-out
  3. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove front of center console panel screws: étape 3, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove front of center console panel screws: étape 3, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove front of center console panel screws: étape 3, image 3 de 3
    • Now you can remove those two counter-sunk screws holding in the front of the shifter/center console panel.
  4. Mercedes-Benz 114 or 115 Auto shifter bushings, Pull up on single clip at rear of centre-console trim: étape 4, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Pull up on single clip at rear of centre-console trim: étape 4, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Pull up on single clip at rear of centre-console trim: étape 4, image 3 de 3
    • The hardest, or second-hardest step
    • There is a simple metal trim clip holding the rear of the centre-console trim panel down (marked by a yellow box in photo 2)
    • You won't be able to see it easily, you can pry back the rubber trim in the marked area to gain a view of the clip (blue box area in photo)
    • In my car the plastic foot with the metal clip attached to it is cracked, so I added a small bit of wire to help pull it out next time so as not to break it (see red box in 3rd photo)
  5. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove connectors and remove the panel: étape 5, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove connectors and remove the panel: étape 5, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove connectors and remove the panel: étape 5, image 3 de 3
    • Ensure your handbrake is set, or you're not on a slope
    • Shift to neutral or other gears as required to get the console panel out
    • You'll need to angle the trim panel back and forth a little as the plugs for your hazards and rear defroster/demister get in the way
    • I've shown the units and their plugs in Yellow (demister) and Red (hazards)
  6. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove the shifter backlight: étape 6, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove the shifter backlight: étape 6, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove the shifter backlight: étape 6, image 3 de 3
    • It's simply clipped-in and you can pry using a small flat-head at the top to get it started
    • When you're re-installing it, you simply line up the V symbol on the shifter housing with the V symbol on the lamp holder
  7. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove 3 bolts holding down the shifter surround: étape 7, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove 3 bolts holding down the shifter surround: étape 7, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove 3 bolts holding down the shifter surround: étape 7, image 3 de 3
    • You'll need a 10mm socket - I used a 1/4in deep
    • There are 3 bolts, one on the right-side and 2 on the left
    • They have a small wavy washer, don't drop it down the centre-console when you pull them out
    • You won't be able to remove the surround fully until the next step
  8. Mercedes-Benz 114 or 115 Auto shifter bushings, Unscrew the shift lever and knob: étape 8, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Unscrew the shift lever and knob: étape 8, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Unscrew the shift lever and knob: étape 8, image 3 de 3
    • First loosen the 15mm jam nut (outlined in red)
    • Now you can unscrew the shift lever/knob
    • When you're re-installing it ensure it's clocked correctly before tightening the jam nut
  9. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift linkage housing bolts: étape 9, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift linkage housing bolts: étape 9, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift linkage housing bolts: étape 9, image 3 de 3
    • There are four 10mm bolts, the left two bolts are hard to see, you'll need to pry the trim back a bit
    • The top-left bolt has the ground cable for the shifter backlight on it
    • The bolts have large flat washers on them, be careful not to drop them down the side of the console - use a magnet if necessary
  10. Mercedes-Benz 114 or 115 Auto shifter bushings, Disconnect the shift rod: étape 10, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Disconnect the shift rod: étape 10, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Disconnect the shift rod: étape 10, image 3 de 3
    • After lifting up the shifter housing (black plastic part) you'll see it's attached to the shift rod below
    • The green thing in the picture is the driveshaft
    • To get better access, you can pull the shift rod towards the rear of the car (go through a few gears) as I did
    • The clip is fairly easy to remove with needle nose pliers and/or a small flat-head screwdriver
    • Be careful not to drop the clip down the side of the centre console or through the hole in the tunnel now revealed
    • These photos are actually from re-assembly, as you can see I lubed up all bushings with 3M Silicone paste - you could use any plastic-safe lube
  11. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove "half-moon" from the housing: étape 11, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove "half-moon" from the housing: étape 11, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove "half-moon" from the housing: étape 11, image 3 de 3
    • You'll see a plastic half-moon part (to stop dust and noise from entering the car) - it just pulls out
  12. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 1: étape 12, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 1: étape 12, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 1: étape 12, image 3 de 3
    • Remove a clip from one end of the small rod connecting the shift lever yoke to the main rod
    • Again as these photos were taken during re-assembly there is silicone lube present
    • You can see there is a tiny bushing in between the spring and the small rod on each end - these bushing are optional but cheap, mine were completely gone
    • The small bushing part number is: 1152670950
    • I used a small screwdriver and needle-nose pliers to remove the clip (slide in direction of red arrow)
  13. Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 2: étape 13, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 2: étape 13, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Remove shift lever yoke - part 2: étape 13, image 3 de 3
    • Some better views of those tiny bushings as you pull the small rod out (slide rod out in direction of arrow)
    • These photos were during re-assembly so the bushing is fresh and clear, the old ones would probably be yellowed or cracked or missing
    • I put a blue circle on one end of the small rod and a red circle on the other end so you can identify them better
    • I used again the small screwdriver and needle-nose pliers to pry the spring back while re-inserting the bushings
  14. Mercedes-Benz 114 or 115 Auto shifter bushings, Shift lever yoke parts: étape 14, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Shift lever yoke parts: étape 14, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Shift lever yoke parts: étape 14, image 3 de 3
    • And a final show of parts involved to attach/detach the yoke from the shaft
  15. Mercedes-Benz 114 or 115 Auto shifter bushings, The snap ring: étape 15, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, The snap ring: étape 15, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, The snap ring: étape 15, image 3 de 3
    • Now the hardest or second-hardest step
    • Removing the snap-ring
    • If you have small snap-ring pliers this is probably pretty easy
    • If not you might be lucky like I was and the needle-nose tips fit into the holes
    • Even so it was a challenge to install and remove the snap-ring
    • Also the part will probably go flying, so do the disassembly in a place where you can find it if it goes flying
    • The washer goes under the snap ring
    • As you can see these photos are from re-assembly, my old bushing was yellowed and the left-side in pieces
  16. Mercedes-Benz 114 or 115 Auto shifter bushings, Slide out main shift rod: étape 16, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Slide out main shift rod: étape 16, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Slide out main shift rod: étape 16, image 3 de 3
    • Finally you can slide out the main rod from the plastic housing
    • Here you'll see why you had to remove the plastic half-moon part
    • After you've got it all apart, the bushings (if any remain) should just push out
    • I cleaned up and then lubed the parts before reassembling
  17. Mercedes-Benz 114 or 115 Auto shifter bushings, The bushings themselves: étape 17, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, The bushings themselves: étape 17, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, The bushings themselves: étape 17, image 3 de 3
    • My old bushing(s) vs the new parts
    • The second image is how the bushings are oriented on the part
    • The third image is the silicone paste lubricant on the bushing, ready to be slid back into the housing
    • Follow the steps in reverse order to re-assemble
  18. Mercedes-Benz 114 or 115 Auto shifter bushings, Wrap up and Tools: étape 18, image 1 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Wrap up and Tools: étape 18, image 2 de 3 Mercedes-Benz 114 or 115 Auto shifter bushings, Wrap up and Tools: étape 18, image 3 de 3
    • The main tools I used were Philips #2 screwdriver (not pictured), small flat-head screwdriver, small needlenose pliers, 10mm deep socket and drivers
    • Consumables were 3M Silicone Paste, paper towels and a bit of Brake cleaner
    • The car being worked on, an Orange Mercedes-Benz 1976 230.6 (type 114.015) with automatic transmission, in Right-hand drive as this is in New Zealand
2 autres ont terminé cette réparation.
Gaspard Leon
Membre depuis le 04/24/10
2 831 Réputation
8 tutoriels rédigés
Un commentaire
Make more /8 guides these are great!
Kaelor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 45
Total : 2,761
